ISM and RTS question
OK, got a question that I am having a really hard time finding.
I do get a lot of returns on RTS and TRIM, but nothing on this question.
So for a while I have been really used to IMS (Intel Matrix Storage). Now that RTS has downloads out for what is replacing IMS my question is this.
Do I uninstall IMS Reboot
and
Install RTS = Thats it?
Also the latest version I have is
9.5.7.1002 ..........Anything newer?
I wouldnt keep both since they both do the same thing right?
Specs
Rampage II Extreme (Intel Chipset)
2 Intell SSD's G2 80GB
2 HDD RAID 0
Thanks for all the expert help!
John
1 ACCEPTED SOLUTION
DZand
Contributor III
and
Here are my answers:
1. You can install the IRST package without any problems. The IMSM software will be uninstalled automaticly.
2. The latest IRST version is 9.5.7.1002.
3. It is impossibe to run both IRST and IMSM simultaneously, because I are doing the same job (but another way).
28 REPLIES 28
Fernando,
And here is another AS SSD result from my other 160GB SSD:
@ambiz.....I dont think TRIM applies to Fernando.....If i remember reading correctly before...he uses a RAID0 setup.....
so manual or automatic doesnt apply to him.
I could be wrong on his setup, so dont quote me on that
John
DZand
Contributor III
@ joconnor3881:
You are wrong regarding my current system. I am running my 2 SSD's as non-RAID disks in AHCI mode since several days for testing purposes, but I will recreate the RAID0 array in the near future.
Regards
Fernando
By the way....I like to add that Diskeeper 2010 w/hyperfast seems to work well. At least for me. I guess it can do till Inter Tool Box supports RAID0 or any other future support.
John
