03-10-2010 02:51 PM
just got a x25-m g2 drive and first thing was to update firmware then installed the os.
i've read that intel drivers dont support trim yet so i stuck with windows 7 ahci drivers (x64)
i went around google and compared my benchmarks and some of mines seem off..
i have tried ssd toolbox, as-cleaner. and still the score turns out around 310-330 on AS SSD
does anyone have any suggestions to improve them, particularly the 4k write is about half of everyone else's that I saw
or do these look good (that I wont notice)?
Thanks!
03-10-2010 05:11 PM
Your sequential read/write numbers look correct. There are some performance benefits on the 160GB drives vs the 80GB drives. So keep that in mind for comparison purposes.
03-11-2010 03:01 AM
I'd say those numbers are not so good. The access times seem to be a problem. Have you disabled write cache? If so enable it and you should; see an improvement. Below is a comparison from my 80GB G2.
AS SSD Benchmark 1.2.3506.28865
Name: INTEL SSDSA2M080G2GC ATA Device
Firmware: 2CV102G9
Interface: IDE
Date: 25/08/2009 13:01:08
Sequential:
Read: 255.83 MB/s
Write: 80.39 MB/s
4K:
Read: 24.81 MB/s
Write: 45.00 MB/s
4K-64Threads:
Read: 151.56 MB/s
Write: 53.66 MB/s
Access Times:
Read: 0.066 ms
Write: 0.084 ms
Score:
Read: 202
Write: 107
Total: 413
03-11-2010 06:34 AM
I have enabled it, anything else I should check?
Could it be faulty?
03-11-2010 07:12 AM
I only change the following from a standard Win 7 install:
Turn off degrag
Turn off system restore: Free up space and make trim run a lot faster. (I use Win 7 disk image for back up)
Turn off hibernate: Free up space
Turn off superfetch
What mobo are you using? Nvidia and AMD based boards don't seem to be as good as Intel based boards when it comes to ssd.
