03-11-2010 01:21 PM
OK, got a question that I am having a really hard time finding.
I do get a lot of returns on RTS and TRIM, but nothing on this question.
So for a while I have been really used to IMS (Intel Matrix Storage). Now that RTS has downloads out for what is replacing IMS my question is this.
Do I uninstall IMS Reboot
and
Install RTS = Thats it?
Also the latest version I have is
9.5.7.1002 ..........Anything newer?
I wouldnt keep both since they both do the same thing right?
Specs
Rampage II Extreme (Intel Chipset)
2 Intell SSD's G2 80GB
2 HDD RAID 0
Thanks for all the expert help!
John
03-11-2010 01:57 PM
and
Here are my answers:
1. You can install the IRST package without any problems. The IMSM software will be uninstalled automaticly.
2. The latest IRST version is 9.5.7.1002.
3. It is impossibe to run both IRST and IMSM simultaneously, because I are doing the same job (but another way).
03-11-2010 01:57 PM
and
03-11-2010 02:03 PM
Thanks Fernando!
Just did it the old fashion way I guess:)
Uninstalled IMS
Installed IRST
So last question...if its new by Intel why is it so hard to find the software? Is it not fully released yet?
John
03-11-2010 03:46 PM
Intel hasn't yet published the Rapid Storage Technology drivers and software v9.5.7.1002, but you can get the complete package inclusive the RST software at Station-Drivers.
03-11-2010 04:23 PM
Sorry for butting in, but I have an Intel X-25V with bios and OS set as AHCI, and Trim is enabled, so should I install this RST 9.5.7.1002
