Intel SSD 530 startup problems - Bug in SSD?
ajoha7
New Contributor II
I just bought an Intel SSD 530 240GB to replace my Intel SSD510 for my HP Elitebook 8460p.
Any ideas on what to do?
Clarification:
216 REPLIES 216
Jose_H_Intel1
Valued Contributor II
Stew, would you please post a picture of Device Manager showing the hard drives section after you uninstalled the Intel® driver? Do you also know the IRST driver version by any chance?
After removing Rapid Storage Technology it looks like the image below. I believe the version was 11.1.5.1001 but I have tried downloading the latest version direct from the Intel site, 12.8.0.1016, and it behaved the same - unable to reboot
Hi Joe,
I'm sorry but you're going to have to be alittle patient since i'm out of town for the remainder of the week, You said you've tested this on multiple HP systems; can you confirm that any of these were equipped with the Intel QM77-chipset? Any other model with any other chipset does not exhibit the issue. I also want to explicitly repeat that not only Intel SSDs have this issue; unfortunately it seems like every one out there with the SF-2281 controller combined with the QM77-chipset are having the issue.
Someone hinted at the RST or Intel SATA conbtroller-driver to be a possible cause of the issue; i'm reaching here but maybe it's a bug related to SATA Link-State power management; if the SSD is shut off at shutdown, and not able to reset (in time) with a warm reboot, it will have to be power-cycled to be able to operate again.
PPetr6
New Contributor II
I am having the same problem with a Macbook Pro and a 240-GB SSD 530 which shipped with the latest (DC12) firmware.
Mac shows the "prohibited" sign* at startup after restart.
At that point, If I shut down by holding the power key pressed, and then boot again, it works.
Mac OS X 10.8.5, clean install.
* prohibited sign:
http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/TS1411/TS1411_1.gif http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/TS1411/TS1411_1.gif
http://support.apple.com/kb/TS1411# symp2 Your Mac won't start up in Mac OS X (Mac OS X 10.3.9 or earlier)
UZiem
Exactly the same problem and behaviour for HP EliteBook 8540w with Intel 530 Series 180GB drive.
SSDSC2BW180A4, FW DC12, HP BIOS version F.23, HDD in AHCI mode, Windows 7 Pro x64 (6.1.7601).
