550 watt power supply allied
08-31-2023 07:52 AM
With its 500W power output, this Allied power supply is well-equipped to handle a wide spectrum of tasks, from everyday office work to intensive gaming sessions. It provides ample power to fuel energy-hungry components while maintaining stability and consistency. The 500W ATX12V Allied power supply is a robust and versatile component that forms the backbone of efficient and reliable computer systems. Tailored to meet the demands of modern computing, it brings together power, efficiency, and safety in a seamless package. Adhering to the ATX12V standard, compatibility is a strong suit of this power supply. Whether you're building a new system or upgrading an existing one, the 500W Allied unit ensures easy integration with various motherboards and cases, making the setup process smooth and hassle-free.
09-01-2023 07:28 AM
Hello jessicaherif,
If we inferred correctly, you are not referring to any Solidigm products. Regarding the product you specified, you would need to contact the original equipment manufacturer.
If you have any questions or concerns, please do not hesitate to contact us via our Support Hub . We will be happy to assist you!
Kind regards,
