X25-M 80GB low 4k read
Hi all,
- system restore off
- index off
- hibernation off
thanks in advance
72 REPLIES 72
I win? I didn't know there was a contest.
Let it not be forgotten you have the msahci driver installed, been a long conversation.
Followed all the steps but unfortunately the results were the same but now I have a strange thing in the device manager:
2 standard AHCI controllers...
Pavle can you post an image of your device manager please?
Did you have Intel® Rapid Storage Technology installed? http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Chipsets&ProductLine=Chipse...
And disable all not needed onboard storage controllers.
I m not at home now. I post screenshot with devices later.
Yes, I installed it and then remove the software like you said
Did you install rapid software then restart and after that removed it? if yes. Try uninstall both AHCI 1.0 controllers manually. Right click, uninstall driver. Reboot. Or try update manually driver from intel rapid software directory or from system if the new drivers exists.
