No restarts with Intel 160GB SSD G2C1
07-25-2010 09:01 AM
Just bought this drive yesterday and installed it into my Alienware M17X-R2 laptop. Fresh install of Windows 7 Pro 64Bit.
First few cold reboots required it worked fine. But after a little while, when trying to restart, the laptop gets stuck. What I mean is I see the external monitor lost signal and go to sleep mode. The 2nd drive sounds like it spins down, but then I remain at a black screen. It seems it shuts down to restart, but never actually restarts and stays on. I have to power down by holdng the power button for 4 seconds, then restart. It boots normally with no complaint of improper shutdown.
The first time it happend when installing the audio driver. Thinking thats what caused it, I reinstalled, but then it happened again with nothing but windows and the intel chipset driver. A few reboots, then nothing else.
I do have AHCI enabled. When running it works great. It's just the cold reboots causing the problem.
Any suggestions?
07-25-2010 12:00 PM
Never mind. Traced it to an ATI driver I was using. I had to go back to alienware's official driver which is several versions old.
Strange that with a regular seagate hdd, it wasnt a problem.
