How to check/enable DIPM on Intel 320??
Options
04-22-2011 11:45 AM
Dear people.
When running Toolbox it says that the DIPM status is unknown because laptop system is detected (which is right).
How do I check and possibly enable DIPM?
It's a brand new Intel 320 160GB...
Thanks in advance 🙂
Regards
sigjanu
2 REPLIES 2
Options
04-24-2011 09:10 PM
Honestly, it should not matter that much.... HIPM or DIPM. The power savings are marginal. Any tweak would have to be user modifications.
Options
04-27-2011 02:48 PM
DIPM status is shown in the Intel Tollbox > System Config Tuner. My status is None - No action required.
EDIT:
