04-10-2011 02:56 PM
Hello everybody. I was wondering if with a Koutech IO-PESA 230 (the pci e SATA 6 gb/s controller I wish to use) I will still be able to run trim on my brand new 510 SSD. It is not a raid card and that really all I've seen that would stop trim. Anybody with an idea would be great. I don't think it will because I haven't seen anybody complaining about issues but better safe than sorry. Thanks, Evilrising
04-11-2011 10:47 AM
I would check with Koutech ??
04-12-2011 08:34 PM
What controller does the Koutech actually use? It should say on the primary chip on the card. i.e. Marvel, PLX, etc?
I don't believe any host-based controllers (other than Intel) have drivers that support TRIM. You would have to make sure the W7 native AHCI drivers will work if you want TRIM.
04-12-2011 08:48 PM
Well my issue is that neither on newegg where I found the card or on koutech's website could I find exactly what controller the card uses. Here is the PDF to the manufactures website on the card. http://www.koutech3.com/public/datasheet/pesa230.pdf http://www.koutech3.com/public/datasheet/pesa230.pdf
04-15-2011 01:24 PM
I can see it right there on the photograph of the card in that PDF. It's a Marvell, assuming that's not a stock photograph.
