05-24-2024 05:40 AM
Just doing my 1st build and have purchased a 2TB P44 Pro Series M2 ssd. My motherboard (Asus rog strix b650e-f) comes with heatsinks reinstalled with a thermal pad fitted.
My question is probably a stupid one.... The ssd has a slip of paper stuck over the top of the ssd chips.... Does this get peeled off before putting the heatsink on so that the thermal pad/paste sticks directly to the chips of does it stay in place so that the thermal pad sticks to it.
Many thanks
06-04-2024 06:22 AM
Dear Cheekytrucker,
Thank you for contacting Solidigm. We would like to advise you not to remove the label (may void the warranty). Our drive should work properly without additional cooling.
If you have any questions or concerns, please do not hesitate to contact us.
Kind regards,
3 weeks ago
Hi James,
You should peel off the slip of paper from the top of the SSD chips before attaching the heatsink. This will ensure that the thermal pad makes direct contact with the chips, providing optimal heat dissipation.
Thank you🙂
