P41 Plus 2TB not detected during driver installation
abe
I have been trying to install the Solidigm Synergy™ Driver for my P41 Plus 2TB SSD, but each time the installer gives the error that a Solidigm SSD was not detected.  I also tried installing the Solidigm™ Storage Driver but got the same error.
What could be causing this issue? I can access the drive on Windows, so I am not sure why the driver installer is unable to detect it.
3 REPLIES 3
SolidigmNebiyu
Moderator
Moderator
Hi abe,
We would like to ask if you are using any type of adapter/enclosure to connect the drive to your system? You may also refer the Solidigm™ User Guide- Driver  #15 to review the limitations of the Synergy™ driver.
If you continue to experience issues with your drive, please use the following link to create a case and we will reach out to you shortly. https://support.solidigm.com/en-US/anonymous-createcase/
Kind regards. 
Nebiyu
I have been able to fix the issue. I just needed to switch the SATA controller setting in BIOS from RAID to AHCI.
Hi abe,
Thank you for the update.
Feel free to reach out to us if there is anything we can assist you with!
Kind regards. 
Nebiyu
