08-31-2016 06:23 AM
Intel NVMe P3600 2.0TB PCIe SSD Adapter SSDPEDME020T4DE Firmware : 8DV10171.
What content is the fimeware 8DV10171 fix or enhancements? Thank you.
08-31-2016 02:41 PM
Hello Jack_Chen,
According to the information you request about the firmware version: 8DV10171, we can let you know the fixes and enhancements are:
-Added functionality to Enable/Disable latency tracking.-Added functionality to parse the read and write commands from latency tracking logs-Added functionality to read and/or modify the SM Bus address for Intel® NVMe* SSD devices only-Updated power governor settings to add support for new Intel® SSD product SKUsYou can also refer to this https://downloadmirror.intel.com/23931/eng/SSD-DCT_3_0_0_Release_Notes_330715-014US.pdf link in case you need further information.
Now, take into consideration the latest version of the firmware is available in this https://downloadcenter.intel.com/download/26221/Intel-SSD-Data-Center-Tool?v=t link .
Let us know if you require anymore information.
Regards,
NC- Mark as New
08-31-2016 02:41 PM
Hello Jack_Chen,
Regards,
NC- Mark as New
09-01-2016 03:01 AM
Intel NVMe P3600 2.0TB PCIe SSD Adapter SSDPEDME020T4DE firmware 8DV101F0 is latest?
09-01-2016 05:29 AM
Hello Jack_Chen,
For the Intel® Solid State Drive DC P3600 the latest firmware version is 8DV101F0. That firmware can be installed with the link we provided in the previous post.Let us know if you need further assistance.Regards,NC- Mark as New
09-08-2016 01:15 PM
Hello Jack_Chen,
We are following up the thread and we would like to know if you require any further assistance.We will be waiting for your response.Regards,NC
