12-02-2013 04:13 AM
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
02-12-2014 03:22 PM
thank you both for checking the response time on your 530s, it definitely seems to be a general problem with this ssd.
i tried disabling hipm and dipm already but as Besovski says it doesn't change anything, the power states are probably controlled by the ssd internally.
making the sandforce controller more efficient is nice but you simply cannot implement a power management which causes response times like an optical disc drive, we really need a fixed firmware.
02-12-2014 04:18 PM
02-19-2014 07:25 PM
Interesting thread. Just wanted to throw out my info after using my intel 530 for around a month and a half.
11-07-2014 05:57 AM
Hello all.
I'm faced to the same problem.
I'm using 240GB 530-series for MySQL database on Linux (yes, I know that it's not the best idea to use it for MySQL, but I had the only option at that time).
My NAND writes was 2.6 times bigger than Host writes.
Searching on the internet gave me nothing, except one link in intel community russian branch https://ru.intel.com/business/community/?showtopic=9283 https://ru.intel.com/business/community/?showtopic=9283
They discovered that the problem is in DevSleep function introduced in new revision of SF-2281 controller. Device is going to energy saving mode too often, and it writes down it's cache to NAND every time it going to that mode.
I wrote a small bash script that reads a small file 8 times per second in infinite loop:
# !/bin/bash
while true
do
dd if=/var/lib/mysql/readme of=/dev/null bs=512 count=1 iflag=direct
sleep 0.125
done
And it really works! While script is running, NAND writes dramatically decreased, and now I have total NAND writes only 1.6 times bigger than host writes.
In addition, the latency also decreased more than twice.
I wonder, is there any way to completely disable DevSleep?
11-18-2014 03:16 PM
evol.ver
Anyway you could write a windows batch file to reproduce your Linux bash script ? I am not experienced to do this. I would like to try this in windows 7 to see if it makes any improvements.
My write amplification continues to increase.
Jonnie
