12-02-2013 04:13 AM
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
02-11-2014 02:02 PM
Thx for info
02-11-2014 02:21 PM
02-11-2014 02:31 PM
02-11-2014 02:41 PM
I really hope that this issue will be fixed with new firmware as soon as possible...
it's not good experiance have 10 times more NAND writes as Host writes.
I noticed that on compressable data behaviour is right for example I see 10 Gb Host writes and only 1 Gb NAND - it's right, but on real life use NAND writes grow much faster as host writes.
Intel support your comments?
02-11-2014 02:49 PM
drive have some issue
i hope Intel team fix this
