Intel Data Migration does not work
10-13-2013 10:43 AM
When migrating from my Hd 180 GB to Intel 335 series 240 GB SSD the computer restarts and then says "Processing, please wait."
After 1 min it says "Acronis Bootable Agent is Waiting for removeble devices."
Nothing more happend. I dont now what it complanes about.
I run Windows XP SP3.
10-14-2013 10:02 AM
Lajban, it seems the Intel® SSD is not being detected properly; please verify the connection and make sure is correctly identified with the model number. If you are using a desktop system try a direct SATA connection, otherwise you want to use an USB/SATA converter that does not mask the drive as USB/ATAPI drive for example.
10-15-2013 12:54 AM
I use a desktop and SSD is connected to sata.
I tested to install the SSD and copy a file to it and that worked.
It looks like the acronis booter cant find the SSD but the message asks for a removeble device.
SSD is not removeble.
10-16-2013 11:18 AM
Please make sure the SSD is connected to the SATA port 0, it is probably connected to a different SATA controller. Do you know what mode is the SATA controller using (AHCI, RAID or IDE)?
10-17-2013 08:49 AM
BIOS and System says that my HDd is IDE.
I have 2 sata contacts solderd to the motherboard (of 4).
My HDd is conncted to the first one and SSD is connected to the secend.
I tried to change the 2 contacts and run Migration program. No difference.
