05-07-2009 02:38 AM
Windows 7 RC supports TRIM command. Are there any plans to update firmware?
tnx
grega_g
05-27-2009 05:11 PM
Thanks Aryan! But I supposed only X25-M would benefit more than X25-E right?
Another thing is, what about Server Core installation? Would it also make use of TRIM? This is especially important for virtualization.
06-04-2009 09:25 PM
I want to add my +1 for a word from Intel on when we can expect TRIM support. I have my x25-m, windows 7 rc1, and now all I'm waiting on TRIM support. C'mon Intel!
06-05-2009 08:36 AM
haxorwear, is your computer running not fast enough?
06-05-2009 09:42 AM
I'm getting excellent read speeds, but the writes are nowhere as good as the OCZ Vertex. A comparison of the same benchmark with different drives:
Block Size
(KB)
Intel X25-m 80g
SSDSA2MH080G1GN, Firmware 045c8820
(read/write MB/s)
OCZ Vertex 30gb
(read/write MB/s)
122528/3370715015/19200464351/10397278610/495561682056/199753126337/969676476075/219292151118/20883525667077/242052156057/207675102465392/276737156979/211366409670363/271695156370/210537819270271/255652154866/210125The only difference is that OCZ has a TRIM tool they provide that allows you to periodically run. Both drives are being benchmarked under Windows7, which has TRIM support but none of the vendors have firmware with TRIM enabled, yet. I'm hoping Intel will make the move to get it out first, giving us the benefit early on.You can see my reads are really good, but the writes are pretty poor in comparison. I didn't expect my X25-M to write half as fast as the OCZ Vertex. Has anyone else noticed this?
06-05-2009 09:53 AM
Your x25-m speeds are according to specification. Even 70MB/s writes. This is probably intentional. Read this article for explanation : http://www.pcper.com/article.php?aid=691&type=expert&pid=1 http://www.pcper.com/article.php?aid=691&type=expert&pid=1
On lower block size test intel is clearly winner in read/write performance as well as in iops. And that is what makes it better for system drive.
grega_g
