x25-M failure
04-10-2010 09:59 PM
-Running Dell 630 with Win08 Server R2 and 8GB RAM;
-X25-M with latest firmware is running on modular bay;
-BIOS (latest) set for AHCI (but same behavior occurs on IDE setting);
-Machine boots, x25 is recognized and Intell SSD Toolbox shows everything ok;
-SSD runs fine and after a few minutes x25 disconnects and is not recognized;
-Modular bay is taken out and back in and x25 is recognized again;
-Trying to also run VHDs on x25 and failure makes it impossible;
-Anyone suggestions are appreciated.
10-04-2010 02:13 PM
I would like you to change the port that you are using along with the cables of the Solid State Drives (power and information); also if you can run a secure erase to this disk, you can download the bootable tool from the following link: http://cmrr.ucsd.edu http://cmrr.ucsd.edu after this you test the Solid State Drive and cannot see the Solid State Drive, I suggest you to test the Solid State Drive in a different compatible motherboard and see if it works there, if the issue persist, please contact the Solid State Drive support phone number: 916 377 7000 option 6.
