X25-M 80GB low 4k read
Hi all,
- system restore off
- index off
- hibernation off
thanks in advance
72 REPLIES 72
I have the exact same drive and my results are very similar to yours. My 4K read is 15.17
This is on a Windows 7 Pro 64 bit clean install. System restore, hibernation all off. Although I still have the previous firmware 02HA.
Don't know if this is relevant but I seem to have duplicate entries in my device manager.. Didn't noticed this before this last windows instalation but speeds were the same as they are now.
I get the same scores as you. Have you tried using the default msahci driver instead of the intel? The msahci driver supports automatic trim in win 7.
I am using the default windows msahci driver as you can see in the benchmark screenshot.
I think the additional controller appeared when I installed the chipset driver of my motherboard. I did run the benchmark tool before the instalation of the chipset and the results are almost identical.
