X25-M 80GB low 4k read
Hi all,
- system restore off
- index off
- hibernation off
thanks in advance
72 REPLIES 72
Well, your motherboard is certainly not old!
I think the issue is your Intel Chipset built in (Intel® P55 Express Chipset built-in) and that is likely why you need to do what pavle suggested, although I don't understand why he didn't tell you that from the beginning!
2 ambizytl
On that point I was thinking it was. Now I think it was something weird thing on what Intel and Microsoft will still work. Because many people was writen about low 4k read speed. And with default settings and drivers peoples get this problem. Now I get lucky and fixed. I dont understand why it was fixes and I m not sure that problem not comes back in the future.
2 lmsilva
And please update you intel chipset drivers to the newest ones:
http://www.station-drivers.com/page/intel%20chipset.htm
Message was edited by: pavle
But this statement by you is misleading and not accurate: I have tried all modes and drivers, AHCI, IDE, RAID. And tried Win 7 x64, x86 and Win XP x64. All setups gives around 15 Mb/s 4k read speed.
You did manage to get normal speeds with same motherboard as him, whether lucky or not. Anyway, I hope your suggestions fix his problem, and I'm sure he will be very grateful if it does.
Pavle do you recommend using those intel drivers over the ones from asus for the chipset?
OK. ambizytl you win. Change all to many and read in that way. Peace.
Yes I suggest to use latest drivers because all new technologys in use, SSD, P55 and Win 7.
