12-29-2010 04:07 AM
I have bought a X25-V and i'm under XP, how to activate TRIM ?
what is his advantage ? i know TRIM is used by defaut on Windows7....
12-29-2010 04:54 AM
Use toolbox to run Optimizer and setup a schedule for it.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng&wapkw=(Solid+State+Drive+Toolbox http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455&lang=eng&wapkw=(Solid+State+Dri...
12-29-2010 12:23 PM
Hello PeterUK,
I have now "This tool is not supported on the selected drive" i really do not understand why... it is my
SSD HD 😞
12-29-2010 08:49 PM
What the motherboard and what driver are you using?
For the SSD Optimizer to work in XP, you need:
1) A 34nm G2 Intel SSD (you have)
2) Firmware version 02HA or higher (should have)
3) Microsoft AHCI or Intel Matrix Storage Manager drivers (I suspect this to the reason)
http://download.intel.com/design/flash/nand/mainstream/Intel_SSD_Optimizer_White_Paper.pdf http://download.intel.com/design/flash/nand/mainstream/Intel_SSD_Optimizer_White_Paper.pdf
12-30-2010 06:22 AM
> Firmware version 02HA (should have)
I have 02HD
My SATA controller are NVIDIA MCP51 so IMSM are not compatible...
TIP ! I have found the solution on a competitor community forum
The second tweak is changing the Nvidia driver to the Microsoft one. Go to Device Manager -> IDE ATA/ATAPI controllers. You should see the device 'NVIDIA nForce Serial ATA Controller', or maybe a few of them depending on how many devices you have installed. Go to properties on each one and for every ****** drive, do the following. Go to Driver -> Update Driver -> 'Install from a specific list or location (Advanced)' -> 'Don't search. I will choose the driver to install.' Select 'Standard Dual Channel PCI IDE Controller' and click 'Next'. Click 'Finish' and reboot.
This tweak is a must for anyone with an Nforce chipset as it gives a great boost in the reads and a small increase in writes.So now it works ! i will answer shortly to give you comparison speed...
