Trim on restored disk images.
If I restore a disk image to an SSD boot drive, will trim recognize the fairly massive rewrite?
Since the restore is done outside windows will the trim process identify the prior locations as usable?
Thank you
1 ACCEPTED SOLUTION
My understanding is that if you are installing Win 7 with MSAHCI or Intel drivers TRIM will work if you run a quick format before Window's is installed. You could do the same thing when installing an image.
I don't think it is advisable to run a full format, but clarity on that from Intel would be helpful.
Clarity on the benefits between preparing a drive in a previously used state with a secure erase or TRIM operation would also be helpful.
That is the key to your question. It's not so much about installing the image with TRIM functionality it's about prepping the drive first if it is in a used state, so you start from fresh.
The safe way to be 100% sure is to run a secure erase on the drive and then install the image. When you secure erase the drive is set back to factory fresh condition.
5 REPLIES 5
Hi DuckieHo, can you please clarify the format issue?
As above my understanding is a quick format is all you need to do if using Win 7.The quick format will initiate a TRIM command and clean the drive.
What happens with a full format? Does it put the drive in a used state?
