System freezes after SRT acceleration enabled
07-14-2011 02:24 PM
I'm looking for guidance or suggestions to a problem that has me stumped. Last week I built a new system based on the Asus P8Z68-V with Intel 311 SSD for Smart Response Technology (SRT) caching. When the SRT is disabled the system is rock-solid stable, and it passes stress tests perfectly. However, shortly after I enable SRT the system begins to intermittently freeze then it becomes 100% non-responsive, which in turn requires a hard-reset. There are no entries in the event log that indicate there was a problem with Windows.
When I first built the system I put both the Intel 311 SSD and accelerated HHD on the two available SATA III ports. About 15 minutes after I first enabled SRT the system began to intermittently freeze, then it completely locked up. After a hard-reset the system would come back up for a few minutes, and then it would freeze again. I did this cycle a few times with the same results, but once I disengaged SRT everything worked normally again. I ran extensive stress tests (Prime95 and Memtest 86+) and found no problems with any components. I then reformatted the HHD, reset the SSD, moved both the SSD and HHD from SATA III ports to SATA II ports, and rebuilt the OS. Once again, about 10-15 minutes after I first engaged SRT the system began to randomly freeze and eventually locked up. Subsequent hard-resets led to similar lockups within minutes. But once I disengage SRT everything works perfectly again. I'm at a loss. I'm looking for additional trouble shooting techniques or guidance as to whether or not to RMA the mobo and/or SSD. Have I missed something? Any help would be appreciated.
Cheers,
TobsterSystem:
Asus P8Z68-V (BIOS v. 0501 and Intel RST v. 10.5.0.1027) I5 2500K (no OC)8GB Corsair Vengeance DDR3 1600 (no OC)Western Digital Caviar 1TB WD1002FAEX-00Z3A0 (accelerated HHD)Intel 311 20GB SSD (cache)Two Samsung 500GB Spinpoint HHDs in RAID 1 (media files w/ backup)EVGA GTX 570Corsair 850W PSOS Windows 7 x64 SP1 w/ all updates- Mark as New
07-21-2011 06:29 AM
I'm hoping someone has some info to provide on this issue. I'm having the same problem, though it takes a few hours for the issue to pop up. I have an ASUS P8Z68-V Pro and an OCZ vertex 2 SSD. Both a regular HD and the SSD work great on their own, but once I accelerate with SRT, the system gets unstable after a period of time, just like you said.
07-21-2011 10:09 PM
Since you are saying the issue isn't occurring until you enable Acceleration, you could try upgrading the RST version to 10.6, which is available online:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20215&keyword=%22Intel+Rapid+Storage+... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20215&keyword=%22Intel+Rapid+Storage+...
Worth a try
07-22-2011 07:56 AM
I actually have. I started with 10.5 and saw the problem, so I updated to 10.6, but unfortunately the problem persists.
07-22-2011 12:04 PM
Are you using your Z68 chipset or the Marvell controller for the SATA 6Gb/s ports?
