05-31-2010 09:31 PM
I am running Windows 7 Ultimate64bit for over a year.
The drive is an SSDA2M160G2GC ATA device
The Sata controller is an AHCI Controller Intel Version 9.6.0.1014
Everything was working fine with SSD Toolbox V1.2Now when I run the SSD Tool box, it starts up, gives the warning about only 1GB of disc space will be left free. I say run, it shows the 0 percent for about 5 seconds and then goes away.The program leaves about 9 hidden files called --=={Intel_Trim_RAID_0}==--.bin--=={Intel_Trim_RAID_1}==--.bin
etc...
I have tried to find a copy of the old v1.2 but I can't. It would be really helpful if someone could pass it along.
I have tried, removing restore points, cleaning disc space, changing drivers, stopping the VSS service.
Does anyone have any clues... this is a tough one.TIA07-20-2010 02:57 AM
Ok I have found a fix for this. All I had to do was disable my kasperky internet security suite 2011 while running the optimizer. Updating from kasperky internet security suite 2010-2011 obviously cause this problem.
07-20-2010 05:41 AM
Chris,
Sadly, a day or two after I posted this, my drive failed to boot. The drive and the data is ok? I put the drive in an enclosure and can access it through a USB port. I have not had time to try and reformat it and re-install. Sad, the best drive I have ever had and can't use it.-WB
07-20-2010 08:46 PM
Maybe ou can try this one,
Try go to the operating system and show all hidden files
Delete the 9 hidden files --=={Intel_Trim_RAID_0}==--.bin you found (usually they have large filesize)
