09-03-2012 10:39 AM
I have a Lenovo T410i with a 320 GB normal HDD to be migrated to SSD 330 Series 120 GB (only aprox 80 GB was used on the 320 GB HDD disk). I use the SSDinstallation tool and the process was simple. However when I switched the old 320 HDD to the new 120 GB SSD i got the message that HW was changed (which it is correct) in the T410i and I was asked to put in the Windows 7 DVD. The W7 installation is preinstalled so I don't have any W7 DVD. Any clue/hint? Is this normal?onT410
09-05-2012 08:05 AM
If your data was all migrated OK , Try running a sys. restore. see what you get than??
09-05-2012 09:23 AM
Thx Robert, system restore from the new migrated disk? But it don't start with the new disk?
09-06-2012 10:51 AM
If you put the old drive back in will the computer run ?? If so look in your documents and see if there is a sys.image file or a sys repair file , They do this on most store bought computers .
