Intel 330 Trouble using Acronis XP Alignment Tool (Says to Contact Intel Support)
Options
08-26-2012 04:30 PM
I installed an Intel 330 SSD in a system using a Gigabyte GA-880GM-D2H running Windows XP x32 using the Gigabyte AHCI driver and when I try to run the XP Alignment tool it does not run and tells me to contact Intel support. I assume this is because it is running AHCI. The Intel SSD Toolbox does see the drive also.
1 REPLY 1
Options
08-26-2012 05:32 PM
Solved.....I changed the BIOS to IDE from AHCI and it let me run it....
