04-10-2011 10:31 AM
I just bought new computer top of the module of each part as follow:
main board GigaByte Intel P67
CPU 17 2600k
16 GB ram 1366Mhz
Nvidia 430
and SSD 120 GB hard drive connected in SATA 3.
i install win 7 64 bit and all work amazing and very very fast until ... i try to connect SATA 2 HD in the moment i add HD on sata 2 the computer become very slow , i connect 2T black WD totaly new and Grenn 1.5T WD in the moment i connect sata 2 HD all system start moving very slow.
I update the chip set all drives are up to date but nothing help me.
any one have any idea why its happen? any idea how to solve this problem ?
thanks
daniel
04-11-2011 10:51 AM
Try connecting the hard drive to the SATA 3 it should be backwards compatable.
04-11-2011 02:32 PM
Is there motherboard a B2 or B3 revision? i.e. When did you purchase the motherboard?
There is a known issue on B2 P67 with the SATA 3Gb/s ports that can cause performance degradation. The SATA 6Gb/s are unaffected. Motherboard manufacturers and Intel are working to replace the B2 for all customers.
06-08-2011 10:53 AM
thr problem was another new HD that was conected to this computer, now all is working perfect... its look like http://www.urbanride.com charter a bus.... i hope WD will handle the replacement in a quick way.
