My SSD is dead ?
12-31-2010 01:15 AM
Hiya
since latest months of 2009 i've runned on my desktop an INTEL SSD X25M-G2 80 Gb..until now...
Yesterday suddenly without any bad advise my Windows 7 prof 64 won't start anymore...
Booting from my secondary HD with Vista 32 i can see the SSD but it is empty and only 8 MB are recognized over 80 GB !!!! I've tried many ways and many recovery software but i cannot still see my 80 GB's...
SSD has worked regularly every day and optimized every week with toolbox....
Someone can help me ?
Thanks in advance and happy new 2011 to all !!
12-31-2010 02:26 AM
I would try a secure erase and if that did not work I'd send it back for RMA. I'd put your chances of getting data back (before the secure erase) as zero.
12-31-2010 02:33 AM
Thanks for answer !
No prob for data...can you tell me what is best software for secure erase and how to run it ?
Thanks again
12-31-2010 03:33 AM
You need to run HDDERASE, which operates in DOS. If you don't have a floppy drive (who does nowadays) you will need to make a bootable disk. If you search this forum there is a thread that explains how to do this. A bit of help can also be found here: http://www.techblo.gg/?p=88 http://www.techblo.gg/?p=88
The Toolbox also runs a secure erase command. If you can plug the drive into another system you might find that easier to do.
From what you describe it sounds like a controller failure, but a secure erase if worth a shot.
12-31-2010 05:21 AM
Many thanks REDUX..
now i try secure erase
