01-08-2011 03:47 PM
Hi.
I just changed my PC and I wanted to install the SSD Toolbox in order to run the TRIM on My X25-M 80Go as I did why my older PC.
But at the end of the installation I get an error message saying the instllation can't end with the error code 0xc0000005.
I tried to find what this error is but the only thing I found was about a RAM problem.
But it succeded the memtest86+ so I think it's not the reason.
I have no more idea.
I'm still using Windows XP SP3 and it used to work before I made format c:.
My firmware version is 02HD
Sorry for my english, I'm french.
Thank you for your help.
01-10-2011 01:57 PM
I have the same problem (same configuration too).
01-10-2011 10:15 PM
You get a BSoD with error code 0xc0000005 during the install of the SSD Toolbox?
Is your motherboard BIOS, OS, and storage driver up-to-date?
Does Event Viewer give you anymore details on the error?
01-11-2011 12:50 AM
Hi !
I dont get a BSOD, it's only an error box with this error code.
My BIOS, OS and SSD firmware are all up to date.
Here is what I get in the event viewer :
Type de l'événement : Informations
Source de l'événement : Application PopupCatégorie de l'événement : AucunID de l'événement : 26Date : 11/01/2011Heure : 08:46:46Utilisateur : N/AOrdinateur : PERSODescription :Application popup : Intel SSD Toolbox.exe - Erreur d'application : L'application n'a pas réussi à s'initialiser correctement (0xc0000005). Cliquez sur OK pour arrêter l'application.Pour plus d'informations, consultez le centre Aide et support à l'adresse http://go.microsoft.com/fwlink/events.asp http://go.microsoft.com/fwlink/events.asp.
I can't see any more information.
01-11-2011 08:37 PM
What motherboard?
