Laptops, SSD, Raid 5 and trim
I have just bought a Sager laptop with Windows 7 64 bit os and have a SSD raid 5.
I have downloaded the new ssd driver that is supposed to support raid 5, but I get the impression it is for desktop support only. Is that true, or will it support laptops as well?
Is anyone using raid 5 on a laptop and able to install the new driver and trim the disks in their raid?
Thank you.
4 REPLIES 4
i dont htink trim is 100% supported on RAID yet.
How do I find out?
RAID is not supported, it doesn't pass through the commands.
But look through here (I assumed you are using an X25
http://www.intel.com/p/en_US/support/highlights/ssdc/x25m-160bv http://www.intel.com/p/en_US/support/highlights/ssdc/x25m-160bv
