Is this speed to be expected?
Good morning every one!
I just got a new PC and installed SSD. Sytem Info and speed as follows:
Model: Fujitsu T900 Tablet
CPU: core i7
RAM: 4 gb
HDD: Intel x25m 80G SSD
I simply removed the existing HDD and replace it with the SSD. Then I did a clean installation. I did not manually install TRIM, Toolbox, Intel driver or Intel Matrix Storage Manager.
My questions are:
1. Is the speed OK?
2. Do I need to install Toolbox, Intel driver or Intel Matrix Storage Manager?
3. TRIM is enabled (I checked with the CMD method) but does it only work when toolbox is installed?
I am a layman and would appreciate your advice. Thank you.
1 ACCEPTED SOLUTION
These are my results:
I'd suggest you follow these instructions and also the link to the SSD toolbox within the pdf: http://www.intel.com/support/ssdc/hpssd/sb/CS-031549.htm http://www.intel.com/support/ssdc/hpssd/sb/CS-031549.htm
10 REPLIES 10
Hi Michael and ZXTT95,
Thank you both for the useful information!
Cheers
