Intel 510s 250gb RAID 0 - Very low performance
08-10-2011 09:25 PM
Hello, 1st post here. I just bought a couple of these drives and picked them over Vertex 3 due to reliability. However I'm running a RAID 0 and getting rather low performance in every benchmark I've tested:
Crystalmark for example:
Seq read: 545, write: 453
512k read: 322, write: 416
4k read: 15, write: 30
4kQD32 read: 159, write: 100
Get very similar results in AS SSD
System:
This is a brand new M18x Laptop
i7 2920xm
8 GB Ram 1866
Windows 7 64
I did a fresh install, disabled the defrag and indexing
My stripe is 465GB and the Raid is configured with 128KB Blocks.
I did install the Intel Rapid Storage Driver
Any ideas?
Thank you.
08-12-2011 09:22 AM
Yup thats the problem, that because port 1 is @ 3gb it's bringing the actual Raid 0 down to 3 gb/s instead of 6gb/s (SATA 3).
08-12-2011 09:06 PM
08-12-2011 10:21 PM
Wow, those are some wild numbers is both benchmarks! Basically exactly twice the single drive speeds. Breaking the 1GB/s barrier with permanent storage, nice.
The 4K numbers are odd, as my single 120GB 510 does better than that, as I imagine each of your 250GB 510's do on their own. I wonder what causes that?
08-12-2011 11:47 PM
Thanks, the numbers are indeed higher than expected (was thinking 850mb/s would be the max) as far as the 4k, I have no ideas why, however I don't really deal with DB's so shouldn't be an issue...
Was just about to replace these guys for the Vertex 3 MaxIops, the price is actually cheaper for the Vertex 3 and performance is about 10-15% on reads, about 40% on writes and around 100%+ on the 4k's.... however I don't think running a raid 0 with OCZ drives is such a good idea from a reliability stand point
08-13-2011 12:02 AM
Yes 4k is still not optimal. Since the values of my SATA II system is better. I guess SpeedStep and C-states are still active.
Please describe for the other users with this problem (Raid0 6Gb / s and 3Gb / s) exactly what had helped.
After the LPM off your problem was still there.
Did you connect the SSD to another port?Or do you work as recommended by me with ThrottleStop?Or Hotplug off ?
