Intel 510s 250gb RAID 0 - Very low performance
08-10-2011 09:25 PM
Hello, 1st post here. I just bought a couple of these drives and picked them over Vertex 3 due to reliability. However I'm running a RAID 0 and getting rather low performance in every benchmark I've tested:
Crystalmark for example:
Seq read: 545, write: 453
512k read: 322, write: 416
4k read: 15, write: 30
4kQD32 read: 159, write: 100
Get very similar results in AS SSD
System:
This is a brand new M18x Laptop
i7 2920xm
8 GB Ram 1866
Windows 7 64
I did a fresh install, disabled the defrag and indexing
My stripe is 465GB and the Raid is configured with 128KB Blocks.
I did install the Intel Rapid Storage Driver
Any ideas?
Thank you.
08-12-2011 07:46 AM
Perfect, that's what I needed, just wanted to be sure Thank you let me do a test run.
08-12-2011 07:53 AM
Before test start thinking about rebooting!
Each Reg - change to the rescan.Have you off SpeedStep?
Have you off C-states?http://forum.notebookreview.com/hardware-components-aftermarket-upgrades/531329-throttlestop-guide.h... Read here interesting information in your language.
EDIT:
I've just seen your stats again from post one.
Please remember, the 510 series is not the best in 4k.
Your changes will not turn out so great.
You see this also in the "test-PDF" one of my previous posts.Do not expect huge gains. If no improvement, then "LPM" turn back!
08-12-2011 08:01 AM
08-12-2011 08:31 AM
Why Port1 as 3Gb / s is displayed?
Maybe there is your problem!?A user in this thread had the same problem. (with C300)
After an exchange of this port was fixed.http://translate.googleusercontent.com/translate_c?hl=de&ie=UTF8&prev=_t&rurl=translate.google.de&sl... post16610939 See here.In the Intel forum, there is also one this thread:
/thread/23997?start=0&tstart=0 Intel 510 SSD Seen as 3Gbs Drive.
Whether it helps I can not say.Your values with the "LPM" off are even less makes no sense.
Or is this at the other "benchmark program"?Too bad I could not help you.
08-12-2011 08:57 AM
Yes the other benchmark I used is Crystaldisk...they are similar. I wouldnt say they went down.
