Intel 510s 250gb RAID 0 - Very low performance
Hello, 1st post here. I just bought a couple of these drives and picked them over Vertex 3 due to reliability. However I'm running a RAID 0 and getting rather low performance in every benchmark I've tested:
Crystalmark for example:
Seq read: 545, write: 453
512k read: 322, write: 416
4k read: 15, write: 30
4kQD32 read: 159, write: 100
Get very similar results in AS SSD
System:
This is a brand new M18x Laptop
i7 2920xm
8 GB Ram 1866
Windows 7 64
I did a fresh install, disabled the defrag and indexing
My stripe is 465GB and the Raid is configured with 128KB Blocks.
I did install the Intel Rapid Storage Driver
Any ideas?
Thank you.
28 REPLIES 28
Sorry I speak no English.
Search "LPM" in Google in your language. Maybe this is your problem.
Alternatively, http://www.derbench.de/index.php/hardwaretipps/1-haenger-mit-ssd-durch-ausschalten-von-intel-lpm-lin... here is a German site. In the bottom of this page contains information from Intel in the English language.
My advice: Do not use the automatic reg files!
If you're technically savvy, then the three Reg-values change manually! The values can always be put back again.
Please give a feedback in this forum!
PS: Secure your system before!
Changes in the registry at your own risk.
Here's a http://www.hardwareluxx.de/community/f227/haenger-mit-ssd-durch-ausschalten-von-intel-lpm-link-power... thread on this subject in German.
(http://translate.google.de/translate?js=n&prev=_t&hl=de&ie=UTF-8&layout=2&eotf=1&sl=de&tl=en&u=http:... same link with Google Translate in english)My post you'll find there on page 8 (RickiBerlin)
Thank you ricky but I don't think this is an LPM issue, I don't have any blue screens, lock ups, my issue seems to be around the SATA/Driver detecting my second drive as a SATA 3 (6gb/s) drive.
This has nothing to do with BSOD and lock ups.
Also, I had no problems.However, the brakes "LPM" 4K performance. And this is a small extent even under "SATA II".
An attempt is worth it in every case.
Switch to SSD Port tentatively "LPM" offThen measure the speed.For me, "LPM" disabled.
Ok fair enough, do the instructions in that link you posted apply to the Intel 510?
