Unable to upgrade my firmware for Intel 600P Series 128GB M.2 SSD
03-09-2017 02:30 AM
Run inside NUC6i3SYK Bios SYSKLi35.86A.0057.2017.0119.1758
Update using SSD Firmware Update Tool is missing Kernel module i915 and X11 will not start.
03-09-2017 07:45 AM
Hello Dave.English
We understand that you're experiencing some problems while trying to update to the latest firmware for your Intel® SSD 600p Series using our Firmware Update Tool.If you're using Windows*, please download and install our latest Intel® SSD Toolbox. You should be able to update your firmware using this tool. - Ihttps://downloadcenter.intel.com/download/26574?v=t ntel® SSD Toolbox Version 3.4.0 (latest).- http://www.intel.com/content/www/us/en/support/solid-state-drives/000006345.html Intel® SSD Toolbox User Guide (Page 27-28).Please post your results, or let us know if you experience issues with this method as well.Best regards,Carlos A.- Mark as New
03-10-2017 12:02 AM
We are don't use windows at all, we are all unix / linux in our corp.
03-10-2017 07:37 AM
Hello Dave.English,
Do you have any different model NUCs, or non-NUC systems capable of supporting the 600p Series that you could use to try and run the Firmware Update Tool in as a workaround?If not, please switch your BIOS to Legacy Mode and disable http://www.intel.com/content/www/us/en/support/boards-and-kits/000006699.html Fast Boot, then try to run the Firmware Update Tool again.If neither of these options work, please let us know.Best regards,Carlos A.- Mark as New
03-13-2017 02:28 PM
That's not the issue X11 will not start with the Firmware upgrade tool, Update using SSD Firmware Update Tool is missing Kernel module i915 and X11 will not start.
