02-16-2017 08:37 AM
Available:
ASUS_PRIME_Z270_P
M. 2 x 4 PCI-Express 3.0 Intel SSD 128 Gb SSDPEKKW128G7X1 600p
Windows 7 SP1 + hotfix for NVMe
Driver: Standard controller NVM Express (stornvme.sys)
Question.
Can not understand, running TRIM or not. When you restart, after a short wait, TrimCheck displays the following:
" First 16 bytes: AE 41 07 45 6C 5F 27 38 EC 17 A0 84 21 52 38 9F...
Data is neither unchanged nor empty.
Possible cause: another program saved data to disk,
overwriting the sector containing our test data.
CONCLUSION: INDETERMINATE.
Re-run this program and wait less before verifying / try to
minimize writes to drive C:."
Codes in the "First 16 bytes:" are constantly the same, instead of 00. What's the problem?
Thankful in advance.
02-16-2017 01:24 PM
Hello Wildcat55,
We'd like to know first where did you get the message for the TrimCheck?Is this disk your boot drive or storage drive?Are you using the Intel® Solid-State Drive Toolbox?Besides this, is the SSD having an issue?We'll wait for your response.Regards,Nestor C02-17-2017 10:54 AM
TrimCheck is a utility for check of operability of the TRIM function. https://github.com/CyberShadow/trimcheck https://github.com/CyberShadow/trimcheck
It is a boot drive.
Yes, I use. Only she doesn't decide what questions concerning this drive.
Other problems aren't revealed yet.
Long didn't respond because of time difference, thanks.
02-17-2017 02:35 PM
Hi Wildcat55,
Thanks for the information provided.We will be looking at this and we will get back to you after some research.Regards,Nestor C02-20-2017 12:39 PM
Hello Wildcat55,
In the meantime, is there any way you can send us the SMART log from Intel® Solid-State Drive Toolbox?You need to click on the export button and then save the *.csv file here. (Make sure to use the advanced editor when attaching the file).Regards,Nestor C
