P3700 Firmware Upgrade
ShawnZBieber
I am aware that official support for the P3700 solid-state drive (SSD) has ceased. Currently, the P3700 is running firmware version 8DV10110,Windows 10 x64 system. I would like to upgrade the firmware to either 8DV10151, 8DV10171, or 8DV101H0. I know that in the past, it was possible to use the Solidigm™ Bootable Firmware Update Tool and the corresponding ISO file to initiate the update, but the download links are no longer available.
2 REPLIES 2
SolidigmGleb
Moderator
Moderator
Dear ShawnZBieber,
Thank you for reaching out. You are correct that the Intel® SSD DC P3700 Series is a legacy product and no longer officially supported. Because of this, firmware packages for that model are no longer maintained or distributed through Solidigm’s current channels.
However, you can still find the Solidigm™ Bootable Firmware Update Tool on our official support page here:
👉 https://www.solidigm.com/support-page/drivers-downloads/ka-00083.html
Please note that newer firmware versions for the P3700 are not listed or validated within this tool, so we recommend continuing to use your current firmware (8DV10110) if the drive is operating normally.
