04-18-2024 01:52 AM
I think the P41 is a better drive then the P44 as its cheaper and has fast lane, although some reviews say that the P44 is faster I think it is not really noticeable for the price therefore the P41 would be a better drive ?
I was thinking of using this in my PC and in a playstation 5.
Ricky
04-19-2024 01:49 AM
Have you checked the website and compared the drives the P44 is better as its longer lasting
BUT if your looking for a general drive P41 will still be good just not as good as P44 - if you just want to use it p41 should be ok . Not sure about the PlayStation.
| Endurance Rating (Lifetime Writes) | 200 TBW- P41 | 500 TBW-P44 |
04-22-2024 05:13 AM - edited 04-22-2024 05:16 AM
Hello ricky,
We would like to inform you, that you can view details and compare our drivers on our web. site.
Regarding the P41 and P44 drives, please find the link where you can compare the characteristics of these drives and decide which products are more appropriate for your purposes.
If you have any questions or concerns, please do not hesitate to contact us via our Support Hub .
Kind regards,
07-09-2024 05:59 AM
I put p41 in mine works fine, no lag.
Jj
