11-11-2014 05:05 AM
I have 32GB SSD drive and it not often in use
I would like to use it as disk on key
Can i do it? Is there adapters from sata to usb or something?
11-11-2014 01:30 PM
If you are saying that you want to use it through the USB port. Yes its possible, I use mine this way. With an USB 3 case I can reach write speeds near 200MB/s. Some tests made from other people show that if you use an USB 3 case that supports UASP protocol, properly configured (it deppends on the USB case and the USB controller of the host supporting that) you can reach near 400MB/s. Some USB cases does not allow you to see the SMART attributes of the drives, and you cannot use TRIM through USB.
11-12-2014 01:19 AM
ok thanks, 2 questions:
1. What i need to buy, to use my ssd as disk on key?
2. Is this product supports usb 2.0?
11-12-2014 03:31 AM
Which drive model you will use?
11-12-2014 03:34 AM
what you mean "drive model"?
