12-08-2020 09:45 PM
How to read S4510 M.2 SATA mode SSD consumption and temperature in Linux system?
12-11-2020 03:15 PM
Hello WShih8,
Thank you for your reply.
To answer your questions:
-How to read current transmit/receive thru-put rate?
R/ Please follow the steps in the following articles:
https://www.intel.com/content/www/us/en/support/articles/000034535.html
https://itpeernetwork.intel.com/how-to-benchmark-ssds-with-fio-visualizer/
These articles include information on how to benchmark SSDs with FIO Visualizer.
The only difference will be to use the Intel® Memory and Storage Tool CLI (Command-Line Interface) https://downloadcenter.intel.com/download/30059?v=t instead of the Intel DCT.
Please follow the steps and the commands available in the User Guide (https://downloadmirror.intel.com/30059/eng/Intel_Memory_And_Storage_Tool_CLI_User%20Guide-Public-342...) section 3.2.5 to prepare the SSD:
delete [-help|-h] [-force|-f] [-output|-o (text|nvmxml|json)] –intelssd
(Index|SerialNumber)
- does the temperature from SMART that it's only controller status or included NAND flash ic
R/ Based on the article Intel® SSD Data Center Family SMART Attributes (https://www.intel.com/content/www/us/en/support/articles/000023512/memory-and-storage/data-center-ss...)
In the Intel® Solid State Drive Data Center for SATA SMART Attributes (PDF) https://www.intel.com/content/dam/support/us/en/documents/solid-state-drives/Intel_SSD_Smart_Attrib_..., you can find the following description of the BEh and the C2h SMART values:
*BEh Case Temperature
Reports the SSD case temperature. Same values as reported in the
attribute C2h.
Raw value suggests 100 - case temperature in C degrees.
*C2h Temperature
The Device Internal Temperature: Reports the internal temperature of the SSD. The temperature reading is the value directly from the printed circuit board (PCB) sensor without offset.
We are going to follow up with you again next Tuesday, the 15th of December 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
We will be looking forward to your reply in case you need further assistance.
Jos B.
Intel Customer Support
12-15-2020 04:38 PM
Hello WShih8,
Greetings from; Intel® Memory and Storage support.
We were reviewing your community thread, which is related to your Intel® SSD D3-S4510. We would like to know if you were able to check our previous post.
We are going to follow up with you again next Thursday, the 17th of December 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
Josh B.
12-17-2020 01:45 AM
Hi Josh,
how to download detail spec?
because our thermal team need more detail for each component temperature limit (T-junction) and we need to check every component is pass or over de-rating requirement.
The critical part be included below:
1. ASIC (Controller) / NAND
2. DRAM chipset
3. PMIC/Inductors/Regulators
Wisely
12-17-2020 04:48 PM
Hello WShih8,
The documentation you are requesting is not available for the public.
We will follow up with you again next Tuesday, the 22nd of December 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
Josh B.
12-17-2020 05:14 PM
Hi Josh,
Are there no document descriptors for that information?
how to guarantee the testing is ok for this SSD (S4510)?
Did we read from the SSD controller temperature below 70°C, and then all components passed the requirements?
