08-31-2016 06:23 AM
Intel NVMe P3600 2.0TB PCIe SSD Adapter SSDPEDME020T4DE Firmware : 8DV10171.
What content is the fimeware 8DV10171 fix or enhancements? Thank you.
08-31-2016 02:41 PM
Hello Jack_Chen,
According to the information you request about the firmware version: 8DV10171, we can let you know the fixes and enhancements are:
-Added functionality to Enable/Disable latency tracking.-Added functionality to parse the read and write commands from latency tracking logs-Added functionality to read and/or modify the SM Bus address for Intel® NVMe* SSD devices only-Updated power governor settings to add support for new Intel® SSD product SKUsYou can also refer to this https://downloadmirror.intel.com/23931/eng/SSD-DCT_3_0_0_Release_Notes_330715-014US.pdf link in case you need further information.
Now, take into consideration the latest version of the firmware is available in this https://downloadcenter.intel.com/download/26221/Intel-SSD-Data-Center-Tool?v=t link .
Let us know if you require anymore information.
Regards,
NC10-19-2016 02:10 AM
As i saw the release note via(https://downloadmirror.intel.com/24739/eng/Intel_SSDDCP3700_P3600_DP04.pdf https://downloadmirror.intel.com/24739/eng/Intel_SSDDCP3700_P3600_DP04.pdf ),
The following firmware upgrades will require 2-step process – 8DV10110 --> 8DV10152 --> 8DV1DP04,
May i know that how can i found the version of 8DV10152 ? Or could you pls provide the download link of 8DV10171?
My product is Intel NVMe P3600 PCIe SSD 2.5in 800GB
10-19-2016 10:51 AM
Hello TigerLiu,
We will send you some information on the other thread you have opened for this request.Thread: https://communities.intel.com/thread/107538 https://communities.intel.com/thread/107538Regards,NC
