Intel SSD 530 startup problems - Bug in SSD?
08-28-2013 08:20 AM
Any ideas on what to do?Clarification:
11-20-2013 10:09 AM
Brandonest: Have you tried updating the BIOS on your W530 with the latest from Lenovo? As I mentioned in one of my earlier posts on this thread, that fixed it for me.
11-20-2013 10:05 AM
Tried this SSD in a Lenovo W530 and HP 8650w
Both cannot restart
Sticking to the Intel 335 SSD until this problem gets resolved
Or possibly never purchasing a 530 again.
Thought Intel was the best.
11-21-2013 02:54 AM
Same problem with HP Elitebook 2560p (with latest HP BIOS).
Uninstalling Intel Rapid Storage Technology and setting power plan to "High" does not help.
So I will wait for Intel SSD firmware update....
11-22-2013 03:57 AM
My 530 just back from RMA on the 21st November 2013 and after cloning was unable to be detected by my ASUS Z87-PRO BIOS after restart too.
Hope Intel will come up with a firmware update soon to solve this problem.
11-22-2013 06:18 AM
Hey fellow Asus owner redot! My Asus G73jh is having the same problem. You're the first Asus desktop motherboard person to check in here (and a new product as well.) Do you have the latest BIOS? I have the MVE board/desktop but don't have any Intel SSDs in that build.
