12-02-2013 04:13 AM
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
11-19-2014 08:46 AM
It has been 8 months since I posted here about this issue. This computer has seen light use, so the total writes are not high, but the write amplification is.
Look at this most recent interval I observed:
Host Writes: 316.66
NAND Writes: 1058
Now ~2 hours later:
Host Writes: 316.75
NAND Writes: 1070
Here are some of my numbers from a while ago when I was tracking this more regularly:
162.41
523
163.22
527
163.88
535
165.28
540
166.72
548
170.41
582
You get the idea. The write amplification can be huge during non write heavy use, occasional large 'actual' writes obfuscate the issue somewhat.
I have all but given up hope that this will be fixed, but it is good to see some recent activity here.
11-19-2014 11:27 AM
Hi Jonnie,
I'm also not experienced in windows scripting. Maybe some of windows power users could do that. There are two important notes about the script: 1) it must read small file directly from drive, i.e. without OS caching; 2) it must read a small amount of data quite often, in my case it reads 512 bytes 8 times per sesond.
And I'd like to repeat my question: is there any possibility to disable DevSleep feature?
11-19-2014 03:47 PM
We are still investigating.
We appreciate your patience and understanding in the meantime.
02-11-2015 12:37 PM
Hello Joe@Intel,
Any news on your investigation?
I my case (240GB 530), after 1 year, it reports 4.5TB host writes and 19.3TB NAND writes
02-11-2015 03:10 PM
The difference you noticed is referred to as "write amplification". This is due to the nature of NAND flash memory, as a data block must be erased before new data can be written to it. This requires extra operations as data is moved, possibly more than once, when new data is written to the drive.
This extra movement of data blocks may involve erases and writes to accommodate a single host write request.
The Intel® SSD 530 Series have built-in features to minimize the write amplification factor (WAF), in your case, it is approximately 4 to 1. This can be higher or lower in different systems, since the WAF depends on the type of workload. In general, small random writes tend to create the largest write amplification values.
For more information, you can check the following documents:
http://www.intel.com/content/dam/www/public/us/en/documents/guides/ssd-technology-terminology-guide.... http://www.intel.com/content/dam/www/public/us/en/documents/guides/ssd-technology-terminology-guide....
http://www.flashmemorysummit.com/English/Collaterals/Proceedings/2011/20110810_T1B_Cox.pdf http://www.flashmemorysummit.com/English/Collaterals/Proceedings/2011/20110810_T1B_Cox.pdf
