fZhan14
New Contributor II
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
154 REPLIES 154
MMill20
One thing that I have noticed for sure is that running HWMonitor greatly increases NAND writes. I run HWMonitor when launching a game for the first time to check temperatures. HWMonitor is stored and run from my secondary traditional drive and yet the impact is undeniable.
before:
host: 320.13
NAND: 1085
after ~1 hour of Farcry 4 with HWMonitor running:
host: 320.44: 0.31GB more
NAND: 1092: 7GB more
Write amplification: 22.6
after ~1 hour more of Farcry4 without HWMonitor:
host: 320.47: 0.03GB more
NAND: 1094: 2GB more
Write amplification: 66.7
Now you can see that there were more host writes during the first run, but I can't see how that would be due to HWMonitor as I have all logging disabled. Also, resource monitor does not show any writes from HWMonitor. The system may well have been doing other writes for any number of reasons, but looking just at the NAND writes I can tell you that this massive increase when running HWMonitor occurs every single time. I have no idea how this could be so since, again, HWMonitor is not an installed application but simply an .exe stored and launched on a secondary drive with all logging features disabled.
Now I realize that the write amplification for the second test without HWMonitor is actually far greater, but since the goal is fewer NAND writes the point and mystery remains. I don't know, the real problem is the write amplification under all conditions, but maybe there is a clue here somewhere.
MMill20
Jonnie, in your post I assume you mean NAND writes went up by 1 GB per hour, not host writes. Host writes would have been 0?
Also, I notice that you have an Asus laptop. I am using an Asus Z87-A motherboard with BIOS version 1207. Anyone else have Asus in common?
ONeum
My system: MSI Z97 Gaming AC motherboard , intel core i7-4790k CPU , MSI 3GB D5 x GTX 780 TI Gaming Grafik,
My Last view:
READ: 809 855 859 869
Write: 460 494 500 502
Nand: 216 484 515 530
ON/OFF: 9 10 11
h ON: 27 29 31
After this i change my SSD to my old Intel 330 and no problems ( i have the win7 on 530 cloned to 330) so it is all the same but 530 its something wrong with many nand in short time.
JChil2
Sorry, "Total Nand Writes" are increasing 1 GB per hour and 0 lba. My mistake, thanks for pointing that out.
JChil2
HWR,
Here is my info:
Motherboard Chipset: Intel HM65 (Cougar Point) [B3]
CPU Brand Name: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
CPU Code Name: Sandy Bridge-MB SV
BIOS Vendor: American Megatrends Inc.
BIOS Version: G73Sw.205
Drive 0 - Boot drive:
Name: INTEL SSDSC2BW240A4 ATA Device
Firmware: DC32
Controller: msahci
Offset: 206848 K - OK
Drive 1 - Data drive
Firmware: DC32
Controller: msahci
Offset: 1024 K - OK
Date: 11/21/2014 5:57:34 AM
