fZhan14
New Contributor II
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
154 REPLIES 154
ARu
I also thinking about "device sleep", but after disabling it on Link Power Management and and disabling on Power Options, huge NAND writes it is certainly exists
ASeva
yeah its not help fix this problem
ARu
let's wait for updates from Intel is how fast they can fix this, if you will have any solution please write here as well
ASeva
i testing tonight device sleep timing.
intel530 have not bad timing but still erase nand
I did a test today using PrimoCache. I set the deferred write to "infinite". No writes went to disk as they were all cached into memory.
"Total Host Writes" increased by 1 GB an hour while the "Total LBA's Written" were 0 over a period of around 6 hours.
I then flushed the cache and rebooted. The Total Nand Writes" did not increase when I flushed the cache (approx. .7GB) and did not change after reboot.
time 8:43
Total LBA's Written 0
Total Nand Writes 3,183
time 10:43
Total Nand Writes 3,185
time 10:52
time 11:52
Total Nand Writes 3,186
time 12:40
Total Nand Writes 3,187
time 2:46
Total Nand Writes 3,189
Flush Cache
Total LBA's Written .7GB
Reboot
