fZhan14
New Contributor II
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
154 REPLIES 154
NFrah
I've made a windows service to read a small part of file and keep the ssd awake.
This is a workaround to avoid the high NAND writes on SSD.
The setup can be downloaded from below link. (500KB)
Setup Disk SSD Read Service 1.0.0.exe
https://drive.google.com/file/d/0BxBcEftvtBxlQVRtbW8tNTJPNkE/view?usp=sharing https://drive.google.com/file/d/0BxBcEftvtBxlQVRtbW8tNTJPNkE/view?usp=sharing
Details about the tasks the service implements:
Once every 100msec, it reads a 4096 byte chunk of its own executable file, bypassing windows caching, into a memory buffer.
It alternates the location of chunk to be read between start of file, and middle of file.
It then sleeps for 100msec, then performs same action until turned off.
(Sleep means it doesn't use cpu usage during that period, program uses less than 1% cpu, mostly 0%)
Because it reads its own file, you can install it on a folder on drive that has SSD. (typically C:\ drive if ssd contains OS).
In a second, you should see approx 36 to 40KB/s activity on ssd.
Your hdd light will blink quickly while it's working.
Service needs .Net Framework 3.5 to be enabled/installed.
Advantage to running as a service is that it starts as soon as windows finishes loading, even before you login or even after you logoff/lock screen.
In task manager it should appear similar to below when pc is idle, 1% and 40KB/sec reads.
I would appreciate your feedback and a note if it solves the issue for you.
DLuka1
php_monkey has created a service: https://github.com/deadbabe/diskpoll GitHub - deadbabe/diskpoll. It reads random 512 bytes from disk and has configurable schedule. 500 ms is enough to get problem solved.
NFrah
I used 500ms and 300ms in previous tests, but on my Intel 535 ssd it didn't seem to solve the issue.
I later saw Cristi's message regarding the script that had 125 ms and configured 100ms in my service.
BKell9
I used the php_monkey service with 200 msec. 500 msec didn't work. My Total NAND Writes/Total Host Writes ratio went from 24:1 to 1:1
Intel 535 SSD
same here, i have 2 SSD intel 535 (240gb per unit) buyed in november 2015, and the principal ssd (windows 10) with the caches (chrome, streams, etc etc) is in a mechanic disk, but the nand writes constantly rises (15gb per hour)
EDIT : 1 hour late Total nand writes increases to 9263gb
