12-02-2013 04:13 AM
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
05-03-2016 02:33 PM
Windows service that php_monkey shared with us works great.
Wonder why Intel does not implement this workaround for now / until a better solution (if there is any) is found.
05-25-2016 12:47 PM
My two months old SSD 535 has the same issue. Host write is around 400GB while nand write is around 2600GB (powered on around 180 hours); write amplification is around 6.5. Tried php_monkey's tool and it works better now (hats off to php_monkey).
The below document has detailed description about device sleep feature. 530/535 SSD will go to devSleep state if Device Sleep Idle Timeout (DITO) is reached. The actual DITO value is calculated by DITO * (DM + 1), where DM is DITO Multiplier.
http://www.intel.com/content/dam/www/public/us/en/documents/technical-specifications/serial-ata-ahci... http://www.intel.com/content/dam/www/public/us/en/documents/technical-specifications/serial-ata-ahci...…
According to http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-535-spec.pdf http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-535-spec.pdf
SSD 535 's default DITO value is 375ms and default DM value is 15; thus the default actual DITO value is 375ms * (15 + 1) = 6000ms = 6s.
So by default SSD 535 will go to devSleep state if it is idle for 6 seconds (the above document does state that "For the Intel SSD 535 Series, the recommended total time to DevSleep for system active state is 6 sec."). However, those DITO and DM values could be set by host according to the document.
I could not find any info about how to figure out these two values for my system......
If the actual DTO value is just 6 seconds, we probably can increase the 500ms interval in php_monkey's tool to a bigger value.
05-25-2016 02:10 PM
I also read that PDF, not so sure about those 6 seconds. In power management there is this Hard Disk think, AHCI Power Management, can be set to HIPM (Host Initiated Power Management / Device Initiated Power Management). I tried to play with them, in the end as service did the job, I just gave up on looking for any other solution. In order to have these entries in power management I had to play with registry as by default they are not present there.
The high temperature for my SSD is related to something else, not to service I did. Behavior is same with either service (mine or the one php_monkey created), temperature goes high from time to time. (could be intensive logging from Windows 10 Pro I have installed). Anyway I prefere php_monkey's service, as is reading data randomly from SSD (mine was reading same file over and over with a flag to not use cache).
In past 13 days Host writes got from 461 GB to 505 GB while Total NAND Writes got from 1997 GB to 2118 GB. (121 / 44 = 2.75 Write amplification, much better then 33 x - the worse I had).
Powered for some 350 hours.
06-09-2016 02:42 PM
@php_monkey, thank you for your workaround.
@jonathan_intel, could you pass the following info to firmware team?
- According to the Intel specification page 21 (see above for link) DevSleep should be activated after 6000 ms = 375 ms × (15 + 1).
- I have tested php_monkey's developed workaround and found that if random 512 bytes are read every 700 ms, background writes do not appear. If 512 bytes are read every 800 ms, background writes appear again.
- I suggest that firmware bug is the following: DevSleep multiplier is 1 instead of 15, so DevSleep is activated not after 6000 ms, but after 750 ms = 375 ms × (1 + 1).
Here are some smart logs:
2016-06-05 18:00:00,06
241 Host_Writes_32MiB -O--CK 100 100 000 - 30845
249 NAND_Writes_1GiB -O--CK 100 100 000 - 12085
2016-06-05 19:00:00,04
241 Host_Writes_32MiB -O--CK 100 100 000 - 30945
249 NAND_Writes_1GiB -O--CK 100 100 000 - 12110
2016-06-05 20:00:00,06
241 Host_Writes_32MiB -O--CK 100 100 000 - 30955
249 NAND_Writes_1GiB -O--CK 100 100 000 - 12137
2016-06-05 21:00:00,07
241 Host_Writes_32MiB -O--CK 100 100 000 - 30966
249 NAND_Writes_1GiB -O--CK 100 100 000 - 12164
2016-06-05 22:00:00,05
241 Host_Writes_32MiB -O--CK 100 100 000 - 31018
249 NAND_Writes_1GiB -O--CK 100 100 000 - 12191
2016-06-05 22:09:37,78
241 Host_Writes_32MiB -O--CK 100 100 000 - 31020
249 NAND_Writes_1GiB -O--CK 100 100 000 - 12195
2016-06-05 23:00:00,14
241 Host_Writes_32MiB -O--CK 100 100 000 - 31182
249 NAND_Writes_1GiB -O--CK 100 100 000 - 12215
06-14-2016 07:25 PM
This issue probably has nothing to do with DevSleep. On my laptop DevSleep is unsupported and DIPM isn't enabled.
However, as mentioned in the above docs, the most common DevSleep multiplier is 1, which means your explanation also makes sense.
