fZhan14
New Contributor II
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
154 REPLIES 154
YLow2
So basically Intel is asking us to finger-cross and hope our SSD die within warranty period for this issue?
I am not sure 13.9x Write amplification is normal for long period streaming technically, but reading posts from 2015 claiming their Intel 320/330 Series SSD write amplification at 1.XX makes me feel sad.
By the way...isn't that the problems are "consistent NAND write while PC is idle", or "abnormally high Amplification"?
CPop
Based on one of the first messages, that suggested that reading from SSD each 200 ms or so you could get rid of this big write amplification, I've created a small windows service. I'm reading from SSD, each 200 ms a small file, this is suppose to prevent SSD from entering into DevSleep mode.
Kinda works, my write amplification dropped from 25 x to ~4x (still nowhere near my older Intel 320 that has a write amplification of just 1.7x). Now I have another issue, might be related to fact that SSD does not enter DevSleep mode anymore, temperature for SSD is in range 52-58 degrees (Celsius) (with DevSleep kicking, was around 45).
I think best solution from Intel would be to give people option for chosing
1. less power consumption (55 mW in idle mode, down to 5 mW in DevSleep mode) / HUGE write amplification (reduced lifespan)
vs.
2. normal power consumption / normal write amplification.
YLow2
Well, maybe the constant read heat up your SSD?
Some people mentioned that Intel used to given out some tools to turn off DevSleep mode, but I believe that is against the design concept for 530 and 535 series. (for Laptop I guess)
Business wise it make no sense to admit the limitation of the design.
I do not know much about technical and can't code, most of the modification is scary to even think about it.
But yes, if 320/330 series is well accepted and 530 series can do it, an option is great to have.
Maybe there's performance issue or other lifespan problem if DevSleep mode is turned off, but just let us know the risks and allow us to choose it.
JBour4
Not sure is it wise to admit failure or not but to me, reputation is valuable asset, since one can't just buy it.
AFAIK, there are reports of other manufacturers' drives having this bug, so it's seems more like controller problem to me. And since AFAIK no one released fix, there is a good chance that it's hardware problem and just can't be fixed with firmware update. So the lesson I've learned - stay away from everything sandforce based.
Anyway, I've made Windows service too (it's https://github.com/deadbabe/diskpoll here, if anyone want to try).
Seems to work, only 1Gb increase per 24h, was 2-3Gb per hour. 200ms might be too often, guys earlier was talking about 500ms. And 45-58C is a waaay to high, mine is 40C even with constant reading, was 36C a bit earlier.
MMuir2
My drive group are still slowly killing themselves.
These drives are not even a year old and they're now below 75%.
This is highly unacceptable.
