fZhan14
New Contributor II
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
154 REPLIES 154
jbenavides
Valued Contributor II
We are looking into this issue in order to identify the cause for this condition.
Please check your private messages, as we would like to get some additional information.
Here's less than 36 hours of activity.
Computer was idle, nobody was in the office.
I did trim the drive, and 2 backups were run.
395GB in NAND Writes with a basically idle machine. 11.25GB/hr.
Checking the taskmanager, host writes match perfectly. The NAND writes do not.
Hi Jonathan,
In my earlier post, I mentioned that I also encountered this problem. Could you also please help to me to check that?
ASouz7
Valued Contributor
Heilaw,
Please check your private messages.
AFíla
attaching export from SSD Toolbox.
