12-02-2013 04:13 AM
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
12-08-2016 05:23 AM
已经更新固件DCV2,看接下来是否解决写入放大问题,非常非常希望intel530 480G能够与自己的intel520 120G一样耐用。
12-08-2016 10:27 AM
Thanks for the firmware update, but my 6 month old SSD (535 480GB) already lost around 10% of its life because of this problem.
Host writes is around 2TB, while NAND writes is a crazy 84TB. It has lost more of its "Estimated Life" in 6 months then SSDs I've had for 5 years!
12-09-2016 01:46 PM
Hello all,
Thanks for your inputs, the FW fix we've provided will help you address your concerns. Please bear in mind that our drives are covered by a 5-year warranty period. You can always contact Intel Customer Support at any time for further questions or concerns at https://customercare.intel.com/?lang=en-US https://customercare.intel.com/?lang=en-US
Regards.
10-02-2019 08:03 AM
I'm having the same problem
04-06-2021 01:06 AM
Looks like they finally dealt with it
The post
My Intel SSD have high NAND writes
Weird non searchable firmware
Download SSD Non-Searchable Fixes and Misc Tools (intel.com)
Dug out my old 530 to scrap together a system for a friend, was shocked to see the write amplification in crystaldiskmark, led to me finding this. Neither the old Intel Toolbox or the new Memory and Storage manager tool automatically download the real fixed firmware, instead claiming DC32 was up to date, it should be DCV2.
This should be fixed.
It wasn't minor write amplification, but 30 times on a drive that was only lightly used!
