12-02-2013 04:13 AM
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
03-30-2016 12:23 AM
Intel SSD 535 series not DRAM-buffer. Recording is carried out without a DRAM-buffer.
04-08-2016 08:25 AM
06-17-2016 05:38 PM
I bought this Intel 535 SSD about 1 month ago, and unfortunately didn't do any research online before buying it. If I had known this notorious write amplification problem, I should't have bought it. Now my NAND write increases about 1GB per 3 minutes in idle state (nearly zero host write). I searched some other site which diagnosed it and determined that intel's aggressive power saving feature is constantly (about every 0.6s) writing back the mapping table because it will go to sleep if there is no activity in 0.6s. This writing back mapping table process will continue to occur even if you disable the DevSleep feature. It is implemented in the firmware. Intel, I really got so disappointed by your action and attitude towards this problem/bug. Please fix the firmware quickly, my and all of our SSDs are dying abnormally quickly! Even an amateur hobby website can determine what the problem is, Why you are so slow and reluctant to fix this? Please FIX it quickly!
08-14-2016 03:49 PM
Should I be concerned with this? I am not sure what the # 's really mean and if it's something to be aware. But I did get value readings from the toolbox and CrystalDisk.
Host Write: 989GB
NAND Write: 17,545.94GB
My life estimaate is still at 100% though... Please let me know.
11-04-2016 12:53 PM
Hi All,
I checked the other day my ssd without much attention because I have Intel SSD since the X-25 M, they are the best right?
But no, this time my attention was caught by over 120 TB of total NAND writes. I implemented the service described earlier in this tread with some improvement (to be seen), but i think this is a warranty problem.
Can someone from Intel describe the procedure I should follow to change the ssd. My ssd warranty expires in 2021, it will not last for sure until then and I don't want to loose my windows activation (upgraded from windows 7 when it was free) or my data.
I am waiting for a Intel response, please.
P.S. Now I have to tell all my friends that my recommendation was wrong, I really hope this can be solved somehow. How can I recommend Intel SSD in the future for servers or PCs when something like this can happen. I have servers that write 100GB per day on ssd, on this kind of write amplification (43) the ssd would last 6 months maximum (750TB). I hope the server ssd versions are better.
